I will try, but this may just make it more confusing so if your head implodes, I take no responsibility.damaralenoire wrote:I would really love to be able to understand all this stuff a lot more. I am really trying to get my head around it but i really need it explained to me.
There is a very wide spectrum of radio frequencies available and their usage is strictly governed in the UK by Offcom.
Bands of frequencies are allocated to different users, for example your FM radio dial goes from 76Mhz up to 108Mhz with good old Radio 4 on 92.5Mhz or thereabouts. Your standard FM radio only receives the signal, it does not transmit. You can understand why Offcom would soon be breathing down your neck if you were transmitting on 92.5Mhz and disrupting the Today program so Offcom allocate separate bands of frequencies for amateur radio users to receive and transmit, within strict guidelines.
FM radio occupies a relatively narrow band and there's a world of other radio 'stuff' going on right the way through the entire radio spectrum. Essentially the lower the frequency, the greater the distance the signal will travel, tune into 7Mhz (High Frequency) and you'll be picking up the darker edges of Europe, tune into 3Mhz and you could be receiving from much farther afield, it's all to do with how the radio waves bounce off the ionosphere.....we'll leave it there, we're drifting into tech-overload!
Go up above 108Mhz and you're into Very High frequency VHF and Ultra High Frequency. These signals do not reflect off the ionosphere as well as so their range is not so great. It's typically line of sight, unless (as Megatron said) you are transmitting with a lot of power. You can pick up some cheap-ish UHF/VHF handhelds which will cover a distance of not much more than 5 or 6 miles, with good line of sight. Buildings and hills will have a detrimental effect upon range.
Malthouse is proposing to use the 70Mhz band. I'm not sure exactly what he's got planned but he may have the right mix of range versus cost. I'm sure he will elaborate in good time.
It's perfectly okay for you to listen on any frequency. It's only if you transmit without a licence then you will fall foul of Offcom. Malthouse may just have the answer with his proposal.
