Need help with Mylar bags
Teapot
Re: Need help with Mylar bags
Post by Teapot »
oh great idea - thanks!! :)
Ian
Post by Ian »
I am not sure why there is a fixation about Mylar bags for storage here in the UK
What is required is an easily sealable bag that does not let oxygen through to degrade the contents, these are called 'barrier bags' of which Mylar is just one type. Oxygen whistles through ordinary Polythene bags, but they effectively stop moisture penetration, all to do with molecule sizes.
Mylar has a couple of layers of plastic which may be easily welded by heat, sandwiching a thin layer of metal, usually aluminium, which of course is an effective block to Oxygen. The plastic layer itself is quite fragile and easily torn.
Other types exist, such as three layers of plastic, outer tough, middle blocking oxygen and inner easily weldable, some have five or more layers for specialist use, e.g. having a tough inner layer for packing sharp materials.
Mylar is typically found in the US and because it is pretty and shiny, for bags of crisps.
In the UK transparent barrier bags are much more commonly used, your cheese, bacon and sausages will be sealed in transparent barrier bags.
All barrier bags slowly let through some oxygen so you put in an oxygen absorber to mop up what comes through, increasing the life of the storage, the bigger the oxygen absorber the longer you may store. For sizing see:
http://www.conservation-by-design.co.uk ... free7.html
Transparent barrier bags are much cheaper in the UK and no less effective than Mylar, and are often tougher. Those of you that use the embossed FoodSaver bags are using barrier bags. Transparent barrier bags are tough enough that you will not need the plastic bucket, a big cost saving I use ex-copier paper boxes that stack well.
Have a wander around the Internet looking for "vacuum pouches", "vacuum bags" and "high barrier bags"
I have used Scobies with no problems:
http://www.scobiesdirect.com/VacuumPouches.asp
Another is:
http://www.thevacuumpouch.co.uk/vacuum_pouches.php
Don't waste money on a fixation that Mylar is the magic storage material that must be used. It is not.
itsybitsy
Post by itsybitsy »
Better seek help for that 'mylar fixation' Teapot. It could be terminall... :lol:
I already decided to do this ian, Mylar is just a designer label fixation I think. If it keeps my porridge/flour/lentils dry and good, then its fine!
Ian
Post by Ian »
I really had in mind another forum which appears to preach 'If you don't use Mylar bags you are a cheap failure' and 'You have to spend a lot of money to keep up with us and prep properly'.
Tosh.
Ian, you are BAD! :mrgreen: :mrgreen:
itsybitsy
Post by itsybitsy »
Ian wrote:I really had in mind another forum which appears to preach 'If you don't use Mylar bags you are a cheap failure' and 'You have to spend a lot of money to keep up with us and prep properly'.
Tosh.
Interesting...care to name and shame? :twisted:
Ian
Post by Ian »
Absolutely and categorically:
NO
(I loath inter-forum wars)
I know. Send me your name on a £20 note and I'll tell you.
(well there's no point being a mod unless there is some pauchle involved eh !) :twisted:
itsybitsy
Post by itsybitsy »
NO
Who's talking about a inter-forum war? It was simply tongue in cheek comment! Hence the smilie...
I don't belong to any more forums - one is more than enough to cope with at times! :lol:
