Thanks Decaff! I suppose it does have to be as often as monthly, doesn't it **groans unhappily** I'm terrible at maintenance, hence the problem with the sink!Decaff wrote:Yayyy good news!!
For the downstairs sink where you can't get the pebble bit out, I would use drain cleaner every month or so, just to remove soap buildup from the pipes. This is my main problem with my pipes, plus being in a flat the drainage is never as good as being in a house as they all go down the same pipe, through the the flat below, through to the bottom then into the ground. If the bottom flat gets bunged up it slowly affects the rest of us...
I don't however use bleach in my home, can't stand the smell of it and am very wary of it being around my mog-splosh. Safer not to have it I thought.
Thats a thought with a flat, about all the flats using the same soil pipe
As far as the smell of the cleaning fluids is concerned, my smell receptors in my nose don't work half the time
