Retreats on the cheap?
Attack Warning Red
Re: Retreats on the cheap?
Post by Attack Warning Red »
Meyou wrote:it has to be well high up, to avoid any 2012 floods...
Do you know something we don't? Care to share it?... :D
Good topic though - I'll be following this one. I've sometimes seen ROC bunkers going on Ebay, but too expensive really. I think the last one went for 20-30k...
the-gnole
Post by the-gnole »
The farmers who owned the land they had the ROC posts on were paid £900 to safe the MOD from backfilling them. :lol:
the-gnole
Post by the-gnole »
http://eastdevon4x4.forumotion.co.uk/t7 ... r-suzuki-s
Found these links on another forum (the one above) for Suzuki info.
Gear calculators
www.grimmjeeper.com/gears.html
diff ratios
http://forum.difflock.com/viewtopic.php ... ht=#274761
Nats Welded Rear Diff Writeup
http://forum.difflock.com/viewtopic.php?t=27773
Fitting a LockRight Difflock.
http://www.nitromax.nl/SAMLOCKER.HTM
Faulty Lockright Locker?
Maybe it needs shimming correctly?
http://forum.difflock.com/viewtopic.php?t=20336
How to change rear wheel bearings:
http://forum.difflock.com/viewtopic.php ... el+bearing
Really Useful Part Numbers
http://forum.difflock.com/viewtopic.php?t=11051
Rear Diff Oil Seal
http://forum.difflock.com/viewtopic.php?t=14086
How to fit UJ's (universal joints)
UJ Info
http://forum.difflock.com/viewtopic.php?p=174775#174775
AISIN Hub Re-Build Guide
http://orc.off-road.com/offroad/article ... ?id=399668
Propshaft extension writeup
http://forum.difflock.com/viewtopic.php?p=140134#140134
Vitara and Grand Vitara Drive Ratios
http://suzuki-grandvitara.info/cms/cont ... y/7/34/64/
Body Lifts
Body Lift How To
http://www.roadlessgear.com/html/techarticles/bodylift/
Bodywork mods and welding
MOT Spec Welding guide
http://forum.difflock.com/viewtopic.php?t=22977
Brakes
Rear disk brake conversions:
http://forum.difflock.com/discus/messages/8/44363.html
http://www.off-road.com/suzuki/tech/backplate.htm
http://www.off-road.com/suzuki/tech/welddiscs.htm
rear disc write up from suzuki club uk
http://www.suzukiclubuk.co.uk/reardiskconversion.html
Bleeding Brakes
http://forum.difflock.com/viewtopic.php ... ght=#73648
Servicing Calipers
http://forum.difflock.com/viewtopic.php ... ght=#72124
http://forum.difflock.com/viewtopic.php ... ght=#49082
Really useful Numbers
Carburettors
Aisin carb strip down and clean guide
http://forum.difflock.com/viewtopic.php?t=7948
SU Carb Conversion
http://forum.difflock.com/viewtopic.php?p=165433
http://suzuki.off-road.com/suzuki/artic ... ?id=277598
Subaru Carb Conversion
http://forum.difflock.com/viewtopic.php?p=177530#177530
Weber carb anti-stall mod:
http://bbs.zuwharrie.com/content/topic,11445.0/all.html
Electrical
Clicky Starter Fix
http://www.off-road.com/trucks4x4/artic ... ?id=277618
http://www.izook.com/reviews/clicky_fix/clickyfix.htm
Starter Motor Rebuild.
http://bbs.zuwharrie.com/index.php/topic,30428.0.html
Spanish SJ Wiring Info
http://www.the12volt.com/info/diagrams.asp
Roof Light Ideas
http://forum.difflock.com/viewtopic.php ... highlight=
Vitara Spotlight Wiring
Norv's Mk2 Golf Headlights into an SJ write up:
http://forum.difflock.com/viewtopic.php?t=26348
Tow bar diagrams 7 and 13pin
http://forum.difflock.com/viewtopic.php?p=300471#300471
Indicators / Sidelights into Bonnet by d86sta
http://forum.difflock.com/viewtopic.php?t=16329
spanish headlight switchgear clean up
http://forum.difflock.com/viewtopic.php?t=35091
1991-2000 transit diesel 90amp with vac pump alternator.
http://forum.difflock.com/viewtopic.php ... alternator
Engine Conversions
Peugeot Diesel Mounts and Gearbox.
http://forum.difflock.com/viewtopic.php?p=226819#226819
VW Diesel Fit
http://www.tomsebooks.com/DieselSamurai.htm
1600 engine AND Powersteering into SJ
http://forum.difflock.com/viewtopic.php ... hlight=pas
Fitting 1600 engine in SJ
http://forum.difflock.com/viewtopic.php?p=4387
Fitting 1600 engine without conversion plate
http://forum.difflock.com/viewtopic.php ... conversion
Wiring 1600 injection
http://www.yankeetoys.org/mini4x/efiswap/efiswap.htm
Where to by pipe work sometimes needed for conversions:
http://www.nfauto.co.uk/gates.htm
Engine mods/General Info
how to fit a vit rad in an SJ
http://forum.difflock.com/viewtopic.php?t=45278
Vitara 1.6 Sump modification
http://forum.difflock.com/viewtopic.php ... sump+++oil
Fuel System Generals
Fuel tank Ideas
http://forum.difflock.com/viewtopic.php?t=17323
Replacing your worn out mechanical fuel pump
http://forum.difflock.com/viewtopic.php?t=32247
Interior Modifications
Door Pockets (Keep those Sandwiches safe!)
http://forum.difflock.com/viewtopic.php ... f13f6ae20f
Rock Sliders and Armour
Box Section Sills
http://forum.difflock.com/viewtopic.php?t=17848
Tubular rock sliders nerf bars build
http://forum.difflock.com/discus/messages/8/46255.html
Petrol Tank Guard
http://forum.difflock.com/viewtopic.php?t=6817
Security
Cheap Suzuki Alarm system
http://forum.difflock.com/viewtopic.php ... eed52461a2
Service Manuals
Full service manual for 413:
http://www.4x4.in.th/manual_sj413
Grand Vitara Service manuals
http://www.auszookers.com/uploads/downl ... Q420WD.pdf
Vitara Service manual (1 of 2)
http://www.auszookers.com/uploads/downl ... 6_1of2.pdf
(2 of 2)
http://www.auszookers.com/uploads/downl ... 6_2of2.pdf
Speedo Recalibration
http://forum.difflock.com/viewtopic.php?t=10988
Steering
Mercedes Steering Arm info;
http://forum.difflock.com/viewtopic.php?t=15553
Hi-steer conversions:
http://www.zukikrawlers.com/showthread. ... t=mercedes
http://www.wazuks.com/forum/viewtopic.p ... t=mercedes
Suspension
coils
*May* be of some use to someone planning coils / Vit solid axle swap etc. Or just for amusement
http://www.racingaspirations.com/macphersongeometry.php
Spring Perch Over Axle Guide (SPOA or SOA)
http://www.zukikrawlers.com/showthread.php?t=174
Bam Bar/Anti Wrap/Traction Bars
http://forum.difflock.com/viewtopic.php?t=25867
http://forum.difflock.com/viewtopic.php ... =axle+wrap
Drop Shackles/Missing links
http://forum.difflock.com/viewtopic.php?p=131069 - Also Discuss' Rears Up Front
http://forum.difflock.com/viewtopic.php?t=10037
http://forum.difflock.com/viewtopic.php ... ght=rascal
Quick Disconnect Anti Roll Bars
http://forum.difflock.com/viewtopic.php?t=10914
Transfercases and Gearboxes
Transfercase Buildup VIDEO
http://www.trail-gear.com/videos/samurai-tcase.wmv
RockLobster:
http://ironbark.bendigo.latrobe.edu.au/~jeff/xfer2.htm
http://www.mallo.nl/english/4.16.htm
http://www.geocities.com/Baja/Outback/3 ... bster.html
http://www.suzukiclubuk.com/rocklobster.html
http://moose.ca/~slowzuki/slowzuki/tech ... /index.htm (information about standard 410 and 413 cases and how to tell them apart)
Transfer Box Cradle
http://forum.difflock.com/viewtopic.php?t=1604
Twin Gearboxes (SJ/Samurai):
http://www.suzuki-samurai.nl/volvo/volvo-eng.html (using a Volvo box)
Twin Transfer Box's on a Vitara
http://forum.difflock.com/viewtopic.php?t=23752
Mating a Sj t box to a Vit gearBox
http://forum.difflock.com/viewtopic.php?t=31904
Wheels and Tyres
Tyres and Rim Widths
http://forum.difflock.com/viewtopic.php?t=18311
What wheels will fit my SJ? Pcd Info
http://forum.difflock.com/viewtopic.php ... hlight=pcd
Winches
Mid-vehicle mounted winch:
http://www.ebroadcast.com.au/ecars/Foers/Winch.html
http://www.4wdonline.com/Foers/Winch.html
http://www.red-ibex.com/vector_winch_system.htm
Pay and play sites
http://www.paynplay.co.uk
And if you cannot find it in here, then try;
Other Suzuki 4x4 Information Resources
Suzuki Modification and Accessory Suppliers
http://forum.difflock.com/viewtopic.php?t=21649
The Suzuki Info Bible!
http://www.acksfaq.com/
MOT manual:
http://www.motuk.co.uk/manual/contents.htm
http://www.suzukitech.org.uk/
http://www.suzukiinfo.com/
SUZUKICLUBUK
http://suzuki.off-road.com/suzuki/artic ... ?id=277595
Jimny Info
http://www.jimny4x4europe.com/
Service Manuals
Jimny
http://www.4x4.in.th/manual_jimny/index.html
Vitara
http://www.4x4.in.th/manual_vitara/index.html
LJ
http://www.4x4.in.th/manual_lj/index.html.
Meyou
Post by Meyou »
Thanks gnole! A lot of these links will come in handy for sure!
As for the 2012 floods...I have a friend who is a bit of a 2012 apocsyclypse expert, and he says there'll be thousand foot high tidal waves...now I don't buy into the 2012 stuff, but that doesn't mean I'm not gonna prepare for it! Expect the worst, be pleasantly surprised when it doesn't happen.
dibley
Post by dibley »
As a Bug out would this web site be useful
http://www.subbrit.org.uk/location
if not for long term at least for a hidden place to meet and go from there.
the-gnole
Post by the-gnole »
dibley wrote:As a Bug out would this web site be useful
I have been in a few of those bunkers and have a friend who was a ROC operative in one of them, I certainly wouldn't want to use them for anything more than a few hours.
And of course they are known to many hundreds of people who probably have their eye on them as well.
Mind you it would be easy enough to get stuck in one, a few concrete blocks on the hatch would be hard to shift from the inside. :shock:
itsybitsy
Post by itsybitsy »
Meyou wrote: As for the 2012 floods...I have a friend who is a bit of a 2012 apocsyclypse expert, and he says there'll be thousand foot high tidal waves....
What, like just appear out of nowhere? If so it doesnt' bode well for me. We can't even get the flood barrier down in less than an hour! :shock:
counsellor
Post by counsellor »
I think you will get more than an hours notice
I think that they are referring to the partial collapse of Tenerife into the sea which would create a massive wave that will sweep across the ocean and then back again
taking out most of east coast USA
itsybitsy
Post by itsybitsy »
counsellor wrote:I think you will get more than an hours notice
Well, having spent two godawful weeks there many moons ago, I don't think it would be a great loss to the world... :mrgreen:
counsellor
Is that Tenerife or / and the east coast of USA :D :D :D
