Signal flares
Easternwind
Signal flares
Hi folks whats everyones thoughts on signal flares/ smoke bombs - have you got them or used them
Everyday is a good day when you are the right side of the grass
Re: Signal flares
They have their uses but have a short ISH life in storage..
They are classified as explosives like fire works
It's illegal to discharge them unless life at risk et all...
Day to day not needed but those who sail ( Solas requirements )or go hill walking if you can justify the weight and hope someone else will actually see it.
As a hang up the helicopter pilot will like smoke as he arrives as it shows wind direction and strength but you need finding first ..
But a decent xenon or led strobe has the advantage as it's multi shot so to speak it and be used continuous until the batteries give up eg
https://www.ebay.co.uk/i/233708430297?c ... 0EQAvD_BwE
Re: Signal flares
Wot Andy says.
I have the exact Strobe in that picture, white blue and infra-red. Takes AA batteries.
Re: Signal flares
Infrared comes in handy used it in anger when an assault happened outside our house I've got contacts at the local CCTV monitoring centre quick phone call ..
point your camera on the mast in the council rec on "any street" at the rail bridge and look for the flash in the bay window and pan down (attacker or victim never knew what got them locked up (with CCTV footage) or help so fast without putting me or my family at risk or exposing my position The guys at CCTV place don't mind as good intel makes them look good
Re: Signal flares
Bird scarers are good legal and range from big bang to smaller ones also comes with fuse .
Just for fun only you could if no one or property was in danger light fuse and place plastic bag full of something over charge for a bigger bang.
Fill er up jacko...
Re: Signal flares
I would strongly discourage anyone from doing this unless you've recieved training in the use of pyrotechnics.
While serving in the RAF I saw a demonstration as to why this is a bad idea, a Sargeant set off a thunderflash just laying on the ground which went off with a satisfying bang, he then set off a second one which he covered with a metal bin lid, when this one went off it threw the lid a good twenty feet into the air.
Confining any explosive charge no matter how small is potentially very dangerous.
Re: Signal flares
Any rapidly expanding gas when constrained behaves more violently. That’s the very nature of explosives and bullets and bombs and fireworks and engines etc.Pete_59 wrote: ↑Sun Oct 25, 2020 1:52 pmI would strongly discourage anyone from doing this unless you've recieved training in the use of pyrotechnics.
Petrol, for example, when a few drops are put onto a mat, will burn with a lazy yellow flame. Put the same amount in a coke can and boom! Ditto diesel. You could drop a lit match into a puddle of diesel and it will go out. Compress the same diesel into a small space and boom! (50:1 compression ratio and you have and engine!)
Re: Signal flares
Personal Locator Beacons can be used on land now they cost around 300 quid with usually about a 7 year battery life
preparedsurrey
Re: Signal flares
My son does Airsoft and the number of thunder flashes and smoke grenades they go through is unreal. Cool to watch though when it's going on towards dusk.
Even the small smoke ones they use burn very hot once going - they had a fire last week.
Occasionally one member brings expired marine smoke things to use which apparently make smoke for a good half hour. I would have thought of you needed to signal these world be the ones to use but they are both large and heavy.
