How about cast aluminium though Tigstigs wrote:the best way to tell if its cast is weight cast iron is really heavy also its a dark colour often black . take a look here http://www.dutchovens.co.uk/
Jam kettle / preserving pan / Dutch oven question?
Re: Jam kettle / preserving pan / Dutch oven question?
cast aluminum is a lot, lot lighter than cast iron , but would also be heavier than pressed aluminum and thicker , cast aluminum cant be cast too thin or it becomes too brittle12mp82 wrote:How about cast aluminium though Tigstigs wrote:the best way to tell if its cast is weight cast iron is really heavy also its a dark colour often black . take a look here http://www.dutchovens.co.uk/
Ready for Anything
Yep, that's pressed and I'd be wary of suspending it over an open fire. Aluminium Dutch ovens are cast. Have a look at this and you will see the difference.
http://www.malikstores.co.uk/product_de ... SiMPmeg7IU
Ah... big difference to the cast aluminium ones!! Never mind - still be good for it's primary use! Thanks for the help all.
Good shot there.
Its a large pressed jam pan with a rolled edge with steel bail and a (useful) pouring handle (that seems to be a plastic material?), made I'd guess in the 70's... Not a bad buy as one not even half as good would set you back over £20
The real prize though is the Paella, I'd say its Cast and then Spun (to true it up, clean the finish and work-harden the surface) probably in Ali (I have a frying pan made the same way). Its serious domestic/ professional grade stuff and would of been expensive when new
The 'lid' I think is just a serving platter of the right size to act as a lid.... Still nice to have
Try to only heat the big pot from the bottom and don't let it get dry(jam pan on the stove or stew pot hung over a small fire) and you should be fine
Either pot would of been a great deal at that price
If it is it is likely to be bakelite, or it might just be enameled steel.and a (useful) pouring handle (that seems to be a plastic material?)
Might be worth keeping an eye out in TKMaxx for dutch oven type castironware, have seen it in there in the past and at a reasonable cost.
Has anyone a system of seasoning the cast iron pans?
treat it like a wock , heat it up with salt in , the salt draws out any oil or dirt in there by the time it turns brown
Ready for Anything
Just searched over on Bushcraft UK site and they have a few things on seasoning cast iron.
This one is particularly good.
http://www.bushcraftuk.com/forum/showth ... +cast+iron
