HUBi
The HUBi system works by collecting daylight and sunlight through its high performance crystalline solar panel and converting this to DC electricity which is fed directly into the Solar Hub containing a safe and light weight Lithium battery pack. Smart internal electronics ensure that the system never gets overcharged and always extracts the maximum from its solar panel.
Unlike the HUBi 2k the HUBi 10k not only has a battery 5 times bigger but it is expandable, allowing you to connect up to 3 units together giving you a huge amount of power.
LUMi lighting
Both HUBi 2k and 10K are supplied with 2 LUMi lights. Each light can be switched via a button on the center point of the LUMi lens and also on the HUBi Solar Hub. Supplied with a 4m cable and hanging hook, each LUMi has a brightness of 40 lumens and this is capable of illuminating a 3m x 3m area. Using the very latest surface mounted LED’s ensures that LUMi’s power consumption is kept to a minimum ensuring long burn times.
If more light is needed, up to four LUMI’s can be powered from a single HUBi solar hub when the LUMi Light Splitter Cable accessory is purchased (sold separately).
Supplied with:
♦ 20w Solar Panel
♦ Solar Panel Stand
♦ 2 x Lumi 12v lights and mounting hooks
♦ Main HUBi 10A unit
♦ All connecting cables
♦ Two year worldwide warranty
The Solar Hub has five output sockets that deliver power;
Technical Spec..
Solar Panel
20w Premium Crystalline solar panel with corner protection
HUBi
Lithium Ion battery for improved power delivery.
10A capacity
Data Panel
LED lights showing charging, available power in battery, and power status (on/off)
Outputs
2 x LUMi lights outputs
2 x USB outputs (MAX 2A)
1 x Car Plug (MAX 3A)
Inputs
Solar Panel charging input
Mains / Expansion HUBi input
Size
HUBi = 220mm x 146mm x 50mm
Panel = 638mm x 278mm x 25mm
LUMi = 120mm x 120mm x 120mm
Weight
HUBi = 1.4Kg
Panel = 2.13Kg
LUMi =
COST £179.99 for the 10 k version.
