I've been told that I might be getting a free ford mondeo estate (think it's a 2010 diesel) long story but it sounds in good nick What should I look out for?
Thanks
ford mondeo estate?
Re: ford mondeo estate?
ask if it`s not to cheeky .. has the fuel pump had any work and the injectors . the rest is run of the mill service type stuff .
- Jamesey1981
If it's free, absolutely nothing, anything that goes wrong you can scrap it if it's not worth fixing and you're up on the deal!
I've an 04 Turbo Diesel. Got it at 5 years old and it's running towards 200k now. I've had the hydraulics in the clutch go, and that was expensive because the cylinder is actually inside the housing, so it's a lot more work than usual (apparently) to fix. The design may have changed between mine and your prospective ride, but mine's got a thing called a "dual mass flywheel", which can wear out and is expensive to replace.
The other thing I had go wrong was a split turbo hose. That wasn't too dear.
On the whole I've been very happy with the car, and over the 7 years I've had it, it's been adequately reliable and economical, while still having enough grunt for civilised motorway cruising. I can't see a newer model tracking back on any of that.
Rattle from the aux belt tensioner means it's on its last legs and needs replacing before it throws the belt
Thanks everybody. It's had a full service history from what I can gather, and done
around 120k miles.
My current motor is showing it's age a bit (starting to look tatty after being hit twice in tescos car park and once in the hospital car park, and I park very carfully too) and I know it's going to need a few things for the MOT, the motor (mazda) is good but it's a bit thirsty as well being petrol.
I'd prefere something smaller but I have to carry four people, shopping and a wheelchair fairly often so I can't get away with anything really small.
Thanks again.
around 120k miles.
Thanks again.
Ford Mondeo is best car I've owned, and I've had all makes. It's just perfect. Not enough seats for my brood now though. Enjoy your new motor!
Like Womble said anything clutch related makes your eyes water with the bill, at least it did mine. Injectors as well, but otherwise very reliable, mine never let me down.womble wrote:I've an 04 Turbo Diesel. Got it at 5 years old and it's running towards 200k now. I've had the hydraulics in the clutch go, and that was expensive because the cylinder is actually inside the housing, so it's a lot more work than usual (apparently) to fix. The design may have changed between mine and your prospective ride, but mine's got a thing called a "dual mass flywheel", which can wear out and is expensive to replace.
Mark Twain
Area 4
Mark Twain
Area 4
Had two Mondeo's and loved them,earlier 1.8td R-reg diesel was awesome,made regular 1000 mile round trips to France and was getting 50mpg, a later 2.0 diesel 53plate was fast and loads of room and averaged 40+ mpg just mooching about,the clutch started to go on that noticed by a slight whistling noise and was a £1000 to change. Got rid for a focus diesel ,biggest load of crap going.
Free Mondeo you can't go wrong,and the heated front screen should be made a standard feature on all cars.
Well it flew through the MOT, it does need a service but I'll get that sorted in the next week or so, when things slack off a bit.
