Slime “Skabs”
PrepperPete
Slime “Skabs”
Post by PrepperPete »
Hi all, just thought I’d make a quick comment about these..
I picked some up at Halfords for bike repair kit (https://www.halfords.com/cycling/bike-m ... ck-patches) and they’re amazingly good for an easy puncture repair.
Admittedly, they’re not super cheap (around £3.49 for a pack of six) but when you get a flat tyre, it’s a lot easier than the old patch and glue kits!
The other use I’ve put them to is repairing small holes in tents - discovered a (2-3mm) rip in my tent roof and one of these, applied over the top, has done a fantastic job of sealing it up.
Anyway, I’ve now got a couple of packs squirrelled away for similar “running repairs” on kit.
Cheers
Re: Slime “Skabs”
I used to do a LOT of mountain biking slime skabs ime along with all the other glueless patches are utter erm rubbish ....
They are useless in wet weather...
They generally leak air over time
They attract muck round their edges
And loose stickyness with age...
Can't beat the age old feather edge patches with vulcanising rubber solution... Buy a pile of the small tubes over a big one as the carrier tends to evaporate from opened tubes of glue...
Most of the time I carried 2 ultra lightweight maxxix presta tubes, (they fit both presta and Schrader rims) a tyre boot, levers and a pump and did my patching at home.... A tampon or ball of cotton wool is handy for finding thorns in the tube
SRAM chain links and a chain tool are a must have plus a spare mech hanger
The slime tyre sealent and puncture bands are not worth the hassle as they don't prevent pinch flats and the slime rarely plugs the hole well enough making a big mess as you attempt to patch it... And you try seating the band's whilst fitting a tyre and tube :?
For tubeless tyres stans no tubes sealent is good both for sealing the bead and fixing small holes on ust tyre and rim set ups but a tube is needed for bigger punctures as reseating the bead without a compressor is next to impossible
Re: Slime “Skabs”
I'll get a pack next time I'm up by Halfords, I like the idea of easy tent repairs in the field (if reqd), thanks for sharing.
Re: Slime “Skabs”
For tent repair (or pretty much any other fabric), I'd recommend clear Tenacious Tape.
It makes no difference if its branded McNett or Gear Aid, its the same stuff
Easy to use, you can cut it to size and it hangs on like an excited terrier
Re: Slime “Skabs”
For 17 years,I commuted by bike 125 miles a week.I have experienced every breakdown a cyclist can; busted wheel,broken crank, and a thousand punctures.There is only one way to fix a flat at the roadside,and that is a spare tube - especially in the dark/rain/snow. Fixthe tube at home in the warm and dry,with proper self vulcanising patches, as Yorkshire Andy said.
yorkshirewolf
Re: Slime “Skabs”
Post by yorkshirewolf »
jansman wrote: ↑Sun Oct 14, 2018 5:15 pm There is only one way to fix a flat at the roadside,and that is a spare tube - especially in the dark/rain/snow. Fixthe tube at home in the warm and dry,with proper self vulcanising patches, as Yorkshire Andy said.
Agree, no point messing about when a new tube can be fitted and pumped up in minutes, just make sure you check the inside of the tyre for spikey things so the new tube doesn't get the same puncture :lol:
I used to use my fingers but have gone a bit soft so use the 'tissue test' - bit of scrunched up tissue run around the inside of the tyre will catch on anything sticking through.
PrepperPete
Re: Slime “Skabs”
Yorkshire Andy wrote: ↑Sun Oct 14, 2018 8:40 am I used to do a LOT of mountain biking slime skabs ime along with all the other glueless patches are utter erm rubbish ....
Thanks for the insight Andy, speaking personally, I’ve never had any bother with them but it sounds like you’ve had a fair bit more experience and I appreciate you sharing!
PrepperPete
Re: Slime “Skabs”
ForgeCorvus wrote: ↑Sun Oct 14, 2018 4:36 pm For tent repair (or pretty much any other fabric), I'd recommend clear Tenacious Tape.
Oooh... I’d not heard of this before, I will investigate further! Thanks!
