Just a reminder to make sure you have enough pickling vinegar etc in your preps.
I wanted to pickle some beetroot and oops, no vinegar. So had to walk to the supermarket to buy some and walk all the way back (in all 2 miles!).
I will now be stocking up on enough stuff to ensure I can pickle/perserve the produce from the garden.
Perserving/pickling
Re: Perserving/pickling
Your local supermaket sells pickling vinegar? Blimey! I wish mine did.
or you could make your own.Just a reminder to make sure you have enough pickling vinegar etc in your preps.
Yeah, in much the same way as you could make your own glass jars.....luxor wrote: or you could make your own.
Hadn't thought about making it!!
Here's what I found......
http://www.vinegarman.com/VinegarMaking.shtml
How to Make Vinegar
Making vinegar is so easy it can be done by accident. We could even say that most of it is made without our cooperation or awareness. Making good vinegar, consistantly, is another story. That requires a little effort. But the effort pays well.
Vinegar can be made from almost anything which contains sugar or starch. It is made from many different things; fruits, grains, roots even wood.
It can be made directly from sugar but is best made by first converting the sugar into alcohol and then turning the alcohol into vinegar. The conversion from starch is a little trickier, but the process shares a lot of similarities.
There are many ways to make vinegar and many of them are covered in our fun easy to read reference book on the subject. But for now let's stick to the very simplest way possible.
To make vinegar the simplest way you need to find yourself;
A container with a spout .(e.g. a sun tea jar) The spout is not mandatory but it sure makes things easier. The container should also have a wide mouth to let in air as well as a way to keep out flies. (Air is very important!) You will be visited by vinegar flies! They are my assistants. The container should be glass or stainless steel for best results. Aluminum and iron is definately out. Some plastics can work, some are dangerous because they react with vinegar. So, for now, I would skip plastics.
Some fresh fruit juice. (Even the frozen variey will do. But I would stay away from the bottled ones because they add chemicals to keep the juice from turning to vinegar. (See how easy it is to make vinegar.)
A starter culture. Notice I said "starter culture". Don't make a big deal about getting a "mother", it will probably ruin otherwise good vinegar. What you need are the bacteria which make vinegar. Check the home brew stores or pick up a bottle of unpasturized, unfiltered vinegar. I have had great success with Braggs Apple cider vinegar. The vinegar in the culture keeps out the other molds and bacteria until the vinegar bacteria have had a chance to take firm control of the juice.
A dark place. You could also paint your jar or cover it . The object is to keep out the light. Light will slow the vinegar production or even kill your culture. A warm place. The precise temperature is not so critical but it does make a difference on how fast your vinegar is made. If you feel comfortable at that temperature, most likely the vinegar bacteria will be happy also.
OK, we have a vinegar culture, a container to put it in, some food for it and lot's of warm air available to it.
Pour about one quart of the starter into the container.
Pour about the same amount of juice into the container.
Put the mix into a warm dark place.
Keep checking it until it is as strong as you like it or it seems to be losing strength.
Bottle it in small bottles. Leave it for at least six months before using. (You could use it right away but, this will make it smoother)
How to Make Vinegar
when i was growing up, my mum and gran used to make ours,Making vinegar is so easy it can be done by accident.or you could make your own.
as it says its very easy.
