help needed with a flue
im putting a multi fueled stove in an out building and its going up through a slate roof, the question is do i need to but an angle in the flue or can i run it straight up from the top of the stove straight up through the roof. Cheers
- Chainsawman
Re: help needed with a flue
You might get water leaks without flashing. Myself I'd keep as much pipe inside (angle it) to give off heat. You need a 'top hat' on it as well; rain water corrodes well in the acidic conditions inside the fire (they all have mild steel fittings).
Seen somewhere a pipe wrapped around the flue to heat water..
- Chainsawman
went off half cocked there - I'd put it through the wall, even if it's 2ft thick consisting of stones and soil, it'll be easier than making it watertight through the slates.
you can run it straight up and fit a rubber flashing.23pioneer wrote:im putting a multi fueled stove in an out building and its going up through a slate roof, the question is do i need to but an angle in the flue or can i run it straight up from the top of the stove straight up through the roof. Cheers
The flue can get very hot, ensure the area were the flue goes through the roof structure is well fire proofed.
JTL
