So, there I was. Finally got a fridge freezer, manhandled it across the deck, carefully let it down the steps. Carried it to the bottom of garden area 1. Then discovered the damn thing was 8"to tall for the area of the prep shed it was going in.
Moving it to the centre of the shed is out because I have to dismantle all the racking and move the preps in situ. (rather a lot of foodstuff).
So. It now has to live outside the shed and I'll camo it with a tarpflex tarp when I can to match the rest of the shed. However.
Do I
a. Keep it upright, fix a huge hasp and staple to each compartment and take advantage of the existing baskets and shelves. (the downside being it's 2 meters tall and can be seen over fences)
Or
b. Build a legged frame and lay it on its back. Hasp & Staple the compartments again, but have in effect a 2 door chest with separate lids. Again camo tarped for weatherproof. (spray the sides with carpet adhesive and roller the tarp on)
Or
c. None of the above ?
Your input is greatfully received.
Murphy Strikes
janso
Re: Murphy Strikes
Hmm..... sounds a bit daft, but can it be 'sunk' down through the flooring? Obviously, the 'hole' would need sheeting out with damp proofing, etc. Bit of a mission I know. How about raising the roof line up to accommodate? This would give more space above for storage?
smileyt
Re: Murphy Strikes
I am assuming you are using it as an insulated 'box' for storage, and not actually wanting to plug it in and use it as a fridge and freezer?
If it's on its back, will rainwater get in? Or will you be fixing a tarp over it like a 'roof'?
WhiteWolf
Re: Murphy Strikes
and if this is how you're intending to use it, will it lay down inside the shed?smileyt wrote:I am assuming you are using it as an insulated 'box' for storage, and not actually wanting to plug it in and use it as a fridge and freezer?
WW
Ogre
Re: Murphy Strikes
Ok. Sorry all.
The prep shed sits on the site of our old above ground pool. So you have inches of stone dust. Then ground sheet, then a load of ballast. Sinking it will be a bitch, plus I lose the use of the bottom compartment.
No electrics, it's out gassed and I was going to rack it as a tool store.
It would have gone on it's side, but the area has now been filled with steel lockers, that have been laid down , tiered and bolted together.
The seals are fine and should keep everything waterproof, but all our preps get bagged and sealed anyway.
smileyt
Re: Murphy Strikes
Then I would lie it flat on its back. You don't want it poking its head above the fence, attracting attention and inviting people to have a look inside!
Ogre
Re: Murphy Strikes
There we go. Opposite the entrance to the prep shed (arkwrights).
And as it's huge, white, out of place and lying down I've named it after me. the ***** Chest
Re: Murphy Strikes
I'd lie it down as well. Keep a low profile at all times
Ogre
Re: Murphy Strikes
Phone call this morn. The mother-in-law. Her freezer has packed in. "Don't throw it out, i'll have it"
Pick it up on Sunday..
(I suppose you could say it never rains but it thaws.....ouch
